Rainer1 Posted June 10, 2021 Report Share Posted June 10, 2021 Hi, Is there simulator/virtual-PLC available. I got information that third party company has made. But how can I get. I have links to that company but they don't work. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted June 11, 2021 MVP 2021 Report Share Posted June 11, 2021 There is no Unitronics simulator. That is an ancient link that worked for a while but I'm guessing Ash abandoned the project. @Cara Bereck Levy - this question about the non-existent VirtualPLC simulator comes up from time to time. Should we just delete these posts from the forum? Joe T. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted June 11, 2021 MVP 2021 Report Share Posted June 11, 2021 39 minutes ago, Joe Tauser said: Should we just delete these posts from the forum? In my opinion, no. It's a good opportunity to explain that a PLC is always the best simulator and is usually cheaper than software simulators for other manufacturers. Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted June 16, 2021 Report Share Posted June 16, 2021 @Joe Tauser, I'll consult further--not sure what to do here. Quote Link to comment Share on other sites More sharing options...
Fernando Castro Posted June 17, 2021 Report Share Posted June 17, 2021 On 6/11/2021 at 2:36 PM, Flex727 said: In my opinion, no. It's a good opportunity to explain that a PLC is always the best simulator and is usually cheaper than software simulators for other manufacturers. well I think that we should compare with similar manufacturers, taking that into consideration codesys is free and I have a virtual PLC with all the capabilities and even servo motors... Sometimes is not always possible to have the hardware or the machine available and you need to simulate and test parts of your code. For example, one time I simulated a complete machine on codesys, I used a virtual axis with specific motion profiles to simulate the actuators and even was able to see the movement and test the logic of my program. indeed I did 2 virtual PLCs running at the same time one was the logic of the machine and the other one was the "machine" itself that responded to the first virtual PLC. And I was able to set up a machine right in my living room without having any physical device connected. Quote Link to comment Share on other sites More sharing options...
