curtharrington1 Posted July 8, 2021 Report Share Posted July 8, 2021 Hello, I would like to monitor the System IO Bus Status and display a text list on the hmi, does anyone know where I can find the list of status codes? Quote Link to comment Share on other sites More sharing options...
Rivka Posted July 14, 2021 Report Share Posted July 14, 2021 Hi, Here are the statuses. @Cara Bereck Levy, I could not find those statuses in help, but I might be mistaken. 0 = OK 1 = Not connected 2 = inconsistent number of connected IOs 3 = configuration mismatch (wrong IO types detected 4 = network error Quote Link to comment Share on other sites More sharing options...
curtharrington1 Posted July 14, 2021 Author Report Share Posted July 14, 2021 Thank you for the info, do you know what drives the Inconsistent Number of Connected IO? It seems like that code would fall under the Config Mismatch code. Quote Link to comment Share on other sites More sharing options...
Rivka Posted July 15, 2021 Report Share Posted July 15, 2021 You're right, we can qualify both codes as "configuration mismatch". But one is because the IO number is wrong and the other because IO types don't match. Quote Link to comment Share on other sites More sharing options...
