Vidmas30 Posted August 18, 2011 Report Share Posted August 18, 2011 Good day, Started new project with V350-35-TU24. Opened my last used application (made with v8.6) made some changes (with v9.3) and when tried to open hardware configuration, popped up error message: TU24 not in a list (capture current screen...) What should i do? I can't open this project with v8.6 anymore.. Quote Link to comment Share on other sites More sharing options...
Ofir Posted August 18, 2011 Report Share Posted August 18, 2011 Hi, In C:\Program Files\Unitronics\Unitronics VisiLogic_C\Data\HW Cfg\Elements List….you will find a file called ElementsList.ini Please enter the file and add V350-35-TU24 to V350 list. 1 Quote Link to comment Share on other sites More sharing options...
Vidmas30 Posted August 18, 2011 Author Report Share Posted August 18, 2011 Thank you, Ofir, it worked;) Quote Link to comment Share on other sites More sharing options...
Vidmas30 Posted August 18, 2011 Author Report Share Posted August 18, 2011 One more thing.. When upgraded V350 to v9.3 new operating system, somethung happened with its colours.. It seems all the colours are a bit lighter and sharpness is gone.. When there was older operating system everything were fine. What happened? Is there any way to fix it? Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted August 18, 2011 Report Share Posted August 18, 2011 Hello, Please make sure that you update the Boot and the BinLib also. Go to help menu>Check for updates>operation system and make sure that your VisiLogic V9.3.0 is up-to-date. Then update the PLC to the latest system files. cheers. Quote Link to comment Share on other sites More sharing options...
Vidmas30 Posted August 18, 2011 Author Report Share Posted August 18, 2011 Thank you, R.Mozes. Visilogic downloaded new OS, I installed it to PLC, but nothing changed.. Even if I tried to change the colour of background, no contrast.. Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted August 18, 2011 Report Share Posted August 18, 2011 Hi, What are the system files versions? can you send me a screenshot from VisiLogic>Connection menu>communication&o/s>operation system>Click on the "CHECK" Button and send me the window of the PLC's versions. thanks... Quote Link to comment Share on other sites More sharing options...
Dz! Posted September 10, 2022 Report Share Posted September 10, 2022 I know the topic is quite old, but recently I have stumbled upon exactly the same problem - the very latest version of Visilogic has no reference to V350-35-TU24, as well as none of the versions back to 9.31 has. Until I searched the forums the situation looked very confusing. It is kinda surprising, because V350-35-TU24 are still actively sold and used, however no one cared to fix the software. Anyway - thanks Ofir once more, for suggestion that worked. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted September 11, 2022 MVP 2021 Report Share Posted September 11, 2022 @Saragani The TU24 issue appears to have been overlooked, so wondering if it could please be rectified. We've also had other models mentioned on the forum that aren't listed, so a little more time fully checking the lists wouldn't go astray. Quote Link to comment Share on other sites More sharing options...
Ivgeny Posted September 21, 2022 Report Share Posted September 21, 2022 @Ausman For TU24, please contact your regional distributor, they will provide you the instructions on how to use it properly. This product is designed for a specific European region. Quote Link to comment Share on other sites More sharing options...
