Buzz_nz Posted February 5, 2022 Report Share Posted February 5, 2022 Hi, I have been asked to work on a V700 Vision with a V100-17-CAN port already installed. How do I find the pinout for the CAN socket. The documentation I have found says the wiring is +V, H, PE, L, -V. This leaves me a 50% chance of getting it right. Cheers Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted February 5, 2022 MVP 2023 Report Share Posted February 5, 2022 Some of the Official Unitronics CANbus Connectors have the terminals actually labelled on the connector. Some don't. If you hold the connector in your hand with the wire entry holes facing you and the screws pointing up, it goes like this: Joe T. Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted February 5, 2022 MVP 2023 Report Share Posted February 5, 2022 I has one V700 on the shelf and install V100-17-CAN for make foto with installed connector 1 hour ago, Buzz_nz said: This leaves me a 50% chance of getting it right. In this topic i post result of my experiment And it turned out that the internal circuit of the CAN card has protection against "change of power polarity". Link to comment Share on other sites More sharing options...
Buzz_nz Posted February 5, 2022 Author Report Share Posted February 5, 2022 23 minutes ago, kratmel said: I has one V700 on the shelf and install V100-17-CAN for make foto with installed connector In this topic i post result of my experiment And it turned out that the internal circuit of the CAN card has protection against "change of power polarity". Thanks Kratmel, your image answered my question. Maybe Unitronics could add an image/drawing to the docs for the V100-17-CAN module showing the orientation. This would leave no doubt regardless of the polarity protection? Thanks again Kratmel. Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted February 5, 2022 MVP 2023 Report Share Posted February 5, 2022 12 minutes ago, Buzz_nz said: Maybe Unitronics could add an image/drawing to the docs for the V100-17-CAN module showing the orientation. This would leave no doubt regardless of the polarity protection? This is absolutely needed. @Cara Bereck Levy, is this something within your purview? Link to comment Share on other sites More sharing options...
