leen Posted May 10, 2022 Report Share Posted May 10, 2022 Hi, We are using password for doing service i.e. remotely. Therefor we using the function 'Password Box' as a function on the HMI. When go remotely with VNC to the HMI. Then we can go into service by give the service code by clicking on the service button and give in the code. Only we have to give in the code by the numeric keybord at the HMI. Then everyone who is there locally can see what code is given in. Is it possible that we can give in the code evenso with te keyboard remotely. This is also easier to give in than by VNC using the mouse and clicking in the code. Kind regards Leen Quote Link to comment Share on other sites More sharing options...
sgull Posted May 10, 2022 Report Share Posted May 10, 2022 Hi Leen Have you tried pressing the visibility button above the keyboard to hide the keypad entry? Regards Denis 1 Quote Link to comment Share on other sites More sharing options...
leen Posted May 12, 2022 Author Report Share Posted May 12, 2022 Ok, thanks. Just simple solution Regards leen Quote Link to comment Share on other sites More sharing options...
greml1n Posted May 29, 2022 Report Share Posted May 29, 2022 I have found that via VNC, once you enter 1 character in the pop-up keyboard you can then use your PC keyboard to fill in the rest of the password without any visual indication of the rest of the password 1 Quote Link to comment Share on other sites More sharing options...
