mario81 Posted May 25 Report Share Posted May 25 Hello, I am new in unitronics. Has anyone tried to connect a two unitronics plc thru a lora TCP/IP thru ethernet port. I have manage to connect two pc s but I am struggle with the plc s Thanks Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted May 25 MVP 2021 Report Share Posted May 25 Please post LoRa devices model #. Some of them cannot be used with PLC. Quote Link to comment Share on other sites More sharing options...
mario81 Posted May 26 Author Report Share Posted May 26 Hi Kratmel, thank you for your reply. EBYTE E90-DTU 900SL22-ETH is the model E90-DTU(900SL22-ETH)_UserManual_EN_v1.4 (1).pdf We manage to connect the plc's together thru the ethernet. We created an adapter node under Ethernet/ip /adapter node and they talking thru cable Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted May 26 MVP 2021 Report Share Posted May 26 mario, what model plcs were they? This post would likely be of use somewhere else on the forum. "Remote Access" refers to a program available, not exactly what you have done. cheers, Aus Quote Link to comment Share on other sites More sharing options...
mario81 Posted May 27 Author Report Share Posted May 27 8 hours ago, Ausman said: mario, what model plcs were they? This post would likely be of use somewhere else on the forum. "Remote Access" refers to a program available, not exactly what you have done. cheers, Aus The plc's we want to connect are USC-B5-R38 and a USP-156-B10. We create a scanner/adapter node. USC-B5-R38 is the scanner and USP-156-B10 is the adapter. On the data cable they talk each other but when we move to the lora units they don't. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted May 27 MVP 2021 Report Share Posted May 27 Thanks, shifted to hardware. Quote Link to comment Share on other sites More sharing options...
