setthasans Posted September 18, 2022 Report Share Posted September 18, 2022 I'm using V280, it is stand alone machine no any network connected. I would like to use the real time clock that always running even power off, could you please kindly advise how to set it up Thank you in advance Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted September 18, 2022 MVP 2021 Report Share Posted September 18, 2022 RTC is embedded to this PLC. You can find time and date in PLC Info mode. If you have project for V280 - you can add RTC to display. If you do not have a project and it is not burned to PLC (upload project is not possible) - you must program new project for add RTC on screen. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted September 18, 2022 MVP 2021 Report Share Posted September 18, 2022 You can also utilize RTC in ladder by using SI 30 - SI 38. There is also plenty of information in the Help file. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted September 19, 2022 MVP 2021 Report Share Posted September 19, 2022 14 hours ago, kratmel said: If you do not have a project and it is not burned to PLC (upload project is not possible) Actually, on a V280 you can upload the program. It's a standard controller that doesn't have upload and burn. If you lose the battery you lose the program. Joe T. 1 Quote Link to comment Share on other sites More sharing options...
setthasans Posted September 20, 2022 Author Report Share Posted September 20, 2022 Thank I have put the RTC in the screen but the time is not running how can I do? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted September 20, 2022 MVP 2021 Report Share Posted September 20, 2022 3 hours ago, setthasans said: I have put the RTC in the screen How exactly did you do this? Can you attach your program? Go online with the controller and look at SI 30 .. SI 38. Is SI 30 (Current second) incrementing? Joe T. Quote Link to comment Share on other sites More sharing options...
