Bishamonten Posted March 30 Report Share Posted March 30 Hi i have a unitronics 1040, i tried to upload the program to the pc but i cant due to the original programmer dont downloaded the program with the Upload project function enabled. Can i see the program conecting the plc to pc using Visilogic? Thanks Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted March 30 MVP 2021 Report Share Posted March 30 No, sorry. Quote Link to comment Share on other sites More sharing options...
Cam Posted March 30 Report Share Posted March 30 No you can't, you will need a copy from the original programmer. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted March 30 MVP 2021 Report Share Posted March 30 If there's an SD card inserted, check that a copy of the program is not on there. Quote Link to comment Share on other sites More sharing options...
