Jhav Posted June 14 Report Share Posted June 14 All, I was wondering what email servers work with the vision software. Quote Link to comment Share on other sites More sharing options...
MVP 2022 Flex727 Posted June 14 MVP 2022 Report Share Posted June 14 Servers without encryption. I'm not sure there are any that still exist. Quote Link to comment Share on other sites More sharing options...
MVP 2022 kratmel Posted June 14 MVP 2022 Report Share Posted June 14 This link to Help center maybe useful https://support.unitronics.com/index.php?/selfhelp/view-article/VisiLogic-Gmail-to-Gmail In Unitronics invitation to webinar i found this Cybersecurity: Vision & Samba Controllers - Unitronics enables Cybersecurity throughout its product range. Join us to learn how you can best protect your system from external threats with Vision and Samba Controllers.July 12th at 10:00 ET | 14:00 GMT Register Here Quote Link to comment Share on other sites More sharing options...
Jhav Posted June 15 Author Report Share Posted June 15 Thank you for the response. I will try Gmail. Quote Link to comment Share on other sites More sharing options...
MVP 2022 Ausman Posted June 16 MVP 2022 Report Share Posted June 16 I haven't tried it with any Vision equipment, but Google does have an innate method for less secure devices to communicate with gmail. It's not well known, but the method is that the google system generates a specific password just for that device, ie it isn't the normal login for the account in use. I had some printers that were being blocked and they are still working fine to this day. Stupidly I did not write up the procedure...kicking myself....but it was fairly easy to step through the process once I had "learned" things. The learning was definitely a bit of trial and error! I recall that the biggest hurdle was having to use the device concurrently with being logged in to the account via PC etc...I think that fairly quick timeouts applied for entering the info. I think that my starting point was here: https://support.google.com/accounts/answer/185833#zippy= and the reference to an "app" is initially confusing, as it isn't an app as such. Again, I don't know whether it works with Vision or not, as I haven't needed it, and at present don't have time to trial things. If someone else has success, please write it up. cheers, Aus Quote Link to comment Share on other sites More sharing options...
ZK0 Posted June 16 Report Share Posted June 16 At our plant, we use a C# script to communicate with the PLC over IP and monitor memory locations in order to trigger an email. I wasn't the responsible party, but if you're interested I can get the programmer to leave a comment here with more details. Quote Link to comment Share on other sites More sharing options...
Jhav Posted June 20 Author Report Share Posted June 20 ZKO, I would be interested in seeing that process if you wouldn't mind. Quote Link to comment Share on other sites More sharing options...
Oath Posted June 20 Report Share Posted June 20 Jhav, Regarding ZK0's answer, we've been using the C# Communications Driver ( https://www.unitronicsplc.com/Download/SoftwareUtilities/unitronics_communication_driver_for_dot_net.pdf ) for most of our monitoring events. We basically poll the memory locations we're interested in about once every second (using the plc.ReadWrite() function) and make decisions or log data from these events. From our experience it can be a somewhat finicky connection, requiring a fair bit of robustness in the program (verifying returned array sizes, type-checking on receipt of your data, a way to handle a communication disconnect, etc), but you can actually end up polling the PLC very rapidly and discard any funky-looking data (for example, if it reads a value that might trigger an email alarm, have it check the next value to see if you're still in an alarm state to mitigate false-positive readings). Once you're collecting the data you're interested in, you can use MimeKit in C# to generate emails in varying formats, including maybe a logfile attachment, and then use MailKit to securely connect to an email service you have available to send a secure email. If you're interested in looking further into this solution, I do have a handful of wrapper functions to simplify my life of interacting with the PLC functions that does a lot of my checking for me on data reads - just let me know! Quote Link to comment Share on other sites More sharing options...
