AlexanderPack Posted February 15, 2019 Report Share Posted February 15, 2019 Я написал программу и нарисовал диаграмму. Можно ли так подключить ПЛК к сервоприводу? Это правильно? step1.vlp Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted February 15, 2019 MVP 2023 Report Share Posted February 15, 2019 google translation: I wrote a program and drew a diagram. Is it possible to connect the PLC to the servo so? It is right? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted February 15, 2019 MVP 2023 Report Share Posted February 15, 2019 Moved to the correct forum. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted February 16, 2019 MVP 2023 Report Share Posted February 16, 2019 V350-35-TU24 is not a valid model number. Is it possibly a V350-35-TA24? If it is a -TA24, you'll want to use either output 0 or 1 in step control mode for the pulse inputs on your stepper. Also note that this model is limited to a 500 Hz output, which may not be fast enough for your application. Joe T. Quote Link to comment Share on other sites More sharing options...
Isakovic Posted February 18, 2019 Report Share Posted February 18, 2019 Hello cyrillic friend, If you want to go faster you need model V350-J-TR34. You could use separate 5V supply for fast outputs if you want to evade the use of resistors. Quote Link to comment Share on other sites More sharing options...
Heitor Posted March 15, 2019 Report Share Posted March 15, 2019 Hi. I need help with of step motor. My machine use two step motors synchronized but in opposite directions. Will i get power two drivers in a HSO? What solution is more easy? Quote Link to comment Share on other sites More sharing options...
Isakovic Posted March 16, 2019 Report Share Posted March 16, 2019 19 hours ago, Heitor said: I need help with of step motor. My machine use two step motors synchronized but in opposite directions. Will i get power two drivers in a HSO? Needs little more info. Which controller are you using and how are you commanding the drives? You can see in the help files possible configurations of high speed channels - https://unitronicsplc.com/Download/SoftwareHelp/VisiLogic_Knowledgebase/PTO_Functions__Simple_Motion_Control.htm What do you mean by synchronized motors, are you cutting circles or something similar? If you need interpolation there are no PTO functions for two axis movement, you'll have to write logic yourself. Quote Link to comment Share on other sites More sharing options...
Heitor Posted March 18, 2019 Report Share Posted March 18, 2019 My process is a revestiment but the product need is moving. I need use two motors, in a witch far end in oposite directions. Quote Link to comment Share on other sites More sharing options...
Isakovic Posted March 19, 2019 Report Share Posted March 19, 2019 So, if I understand this, you have two axis linearly moving from one end to the other. You can use models TR34 or TRA22 and have two channels configured as " Pulse + Direction ", also look at the manual of your driver for steppers. I hope this is enough to get you started working on the details. Check out POT webinar on Unitronic's YouTube page, great stuff. Quote Link to comment Share on other sites More sharing options...
