Streamer Posted July 23, 2017 Report Share Posted July 23, 2017 Dear all, i am new user of UNITRONICS products. I would to introduce myself in Visilogic programming, and i bought SAMBA V43-J-R20 for testing. I have air srew compressor and i want to make a plc program for it. I will use four digital inputs, two analog current input and four or five digital outputs. I was make a screen objects in HMI with some text and the first problem is when i download project in PLC the text objects is invisible on the screen. First picture in attachment (samba1) is from my LAPTOP, and second picture (samba2) is from SAMBA screen... I don`t know where the problem is... The version of Visilogic i use is 9.8.31 build 0, and SAMBA OS is 4.3(06), boot 2.2 (44)... Visilogic is running on win 10, connection is with USB cable and Serial emulation port. can enyone help me with this problem?? Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted July 23, 2017 MVP 2023 Report Share Posted July 23, 2017 Post your code. Link to comment Share on other sites More sharing options...
Streamer Posted July 24, 2017 Author Report Share Posted July 24, 2017 Sorry, i don`t understand... which code? Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted July 24, 2017 MVP 2023 Report Share Posted July 24, 2017 Sorry, that was shorthand for your .vlp file. Link to comment Share on other sites More sharing options...
Streamer Posted July 24, 2017 Author Report Share Posted July 24, 2017 Ah, OK... This is my first steps with visilogic Here is link to vlp file, because its bigger than attach maximum size: https://www.dropbox.com/s/ut9rh8et89tadco/PLC_V2.rar?dl=0 In attachment are the pictures from samba when i download this vlp project.... Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted July 24, 2017 MVP 2023 Report Share Posted July 24, 2017 Unfortunately, I don't have a Samba available, so I downloaded the program into a V700. Everything showed up perfectly, so there is nothing wrong with your program. I suggest the following: -Re-download the program fully. I would pull the power and the battery from the PLC for at least 20 min, then replace both and perform the download. If still the same, then check the status of the firmware by pressing Ctrl-F9 and going to the 4th tab over and press the "Check" button. Upgrade the OS if it says to and repeat the above. If still no improvement, contact your distributor or email support@unitronics.com. I have seen this type of thing before (very rarely) and it was usually some glitch that never repeated once the program was re-downloaded. Link to comment Share on other sites More sharing options...
Gabriel Franco Posted July 24, 2017 Report Share Posted July 24, 2017 I had same behaviour once but with V400. I solved it updating OS, downloading an empty application and then downloading the application again. Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted July 24, 2017 MVP 2023 Report Share Posted July 24, 2017 1 hour ago, Gabriel Franco said: I solved it updating OS, downloading an empty application and then downloading the application again. This has worked for me in the past for similar problems and may be all you need to do. Link to comment Share on other sites More sharing options...
Streamer Posted July 24, 2017 Author Report Share Posted July 24, 2017 I renewed the OS with the latest one, I tried everything you wrote, but without sucess I thing samba has no battery and i don`t know how i can make a reset to factory settings... I attach the pictures of model and OS versions.... Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted July 24, 2017 MVP 2023 Report Share Posted July 24, 2017 You downloaded a blank project then downloaded your project again? Link to comment Share on other sites More sharing options...
Streamer Posted July 24, 2017 Author Report Share Posted July 24, 2017 Yes, i try to download blank project and then my project... Link to comment Share on other sites More sharing options...
sgull Posted July 24, 2017 Report Share Posted July 24, 2017 Hi Streamer Try downloading the latest version of visilogic. When I tried to open your program it said it was made with an older version. If the Samba is new the operating system installed may be newer than your visilogic version, This may cause problems with compatibility. Regards Denis Link to comment Share on other sites More sharing options...
R.Mozes Posted July 25, 2017 Report Share Posted July 25, 2017 Hi, Follow the below steps that show how to solve this font issue. Go to Help > Check for updates > Operation system to update the O/S files. Open a new blank project (HW Configuration only) Go to Connection menu >Communication and OS > 4th tab > Check > Download When it's done updating the PLC's system files, Add a new font. (Any Font) To add a custom font type and size in VisiLogic, go to the font handler and add new font. For more information please go to VisiLogic>Help (F1) Home > HMI Displays > Text > Font Handler Download All & Burn the project to the PLC. Then, open your project > Perform Build-All from build menu > Download All & Burn. I hope it helps. Link to comment Share on other sites More sharing options...
Streamer Posted July 31, 2017 Author Report Share Posted July 31, 2017 Dear ms. R.MOZES, thank you verry much for your help, this was solve the problem.... Now i see every font after downloading the project... I was try everything else, firmware updating, OS, downloading newest visilogic, and nothing helps.... I am happy now, Thank s again.... Link to comment Share on other sites More sharing options...
