peter leeming Posted April 18, 2018 Report Share Posted April 18, 2018 I am rebuilding the controller of the line. My problem is that I need to install the length measureing with a 2500 ppr that countes up and down so I need to use both channel A and B. I cannot get the controller (SM70-J-RA22) to do its thing on the display. What ever I do the count just constantly increasese when input 0 or 1 is switched on. Am I programming it right or is this the wrong device for this job?. You help would be appreciated. It is a clever bit of kit so it should do it. Thank you for your help. Quote Link to comment Share on other sites More sharing options...
Cam Posted April 18, 2018 Report Share Posted April 18, 2018 Peter in your hardware config did you set the High Speed Inputs up as a shaft encoder? Quote Link to comment Share on other sites More sharing options...
peter leeming Posted April 19, 2018 Author Report Share Posted April 19, 2018 Quote I am sorry if I seem dim. All the jumpers are as factory and the inputs are active. I cannot find where to change the hardware config to shaft encoder unless it is in the programming. if so please point me in the right direction. This is the first time I/we have had this type of controller. We have used other plc systems which is madly expensive and this unit is ideal for this small application. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted April 19, 2018 MVP 2021 Report Share Posted April 19, 2018 Upload your .vlp file. (Post your code) Joe T. Quote Link to comment Share on other sites More sharing options...
DanT Posted April 20, 2018 Report Share Posted April 20, 2018 Open Visilogic View HW_Configuration Click on the LOWER box - FULL PART NUMBER SM70-J-RA22 High Speed Inputs Tab none - dropdown - choose the High Speed Function to use ( A-B shaft Encoder x 2) and choose an ML as the operand Using any Analog Inputs and Outputs -- Open the tabs and set them up -- and the related jumpers in the unit AND -- Is the encoder NPN or PNP outputs? -- Set the NPN/PNP Jumper accordingly - And ALL inputs will be either PNP or NPN ! Quote Link to comment Share on other sites More sharing options...
peter leeming Posted April 27, 2018 Author Report Share Posted April 27, 2018 Thank you all for your help. Dan t's solution did the trick. I have the encoder input going into a STI (ML) with the shaft encoder into the ML0, ML1 is blank?. I am picking up ML0 into a A=B block with ML2 set as the target. The machine is a cut to length so when the guillotine cut to size the shaft encoder count needs to zero. I have never used these units before so it twisting me head. I have used mitsubisi, siemens and other controllers so sequencing and logic is not new to me. If I can get the hang of these controllers then there are other applications they will be used on. Thanks again to all Peter Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted April 27, 2018 MVP 2021 Report Share Posted April 27, 2018 10 minutes ago, peter leeming said: If I can get the hang of these controllers In case you don't know, Peter, under Visilogic's Help heading, there are numerous examples that will help you along the learning path. Some may not be for your particular unit, but the principles are generally the same and can make things much easier to absorb. cheers, Aus Quote Link to comment Share on other sites More sharing options...
peter leeming Posted May 2, 2018 Author Report Share Posted May 2, 2018 Hi All. Ref to previous posts, I cannot find any examples of the problem I am having. I cannot find a way of resetting the encoder count to zero before restart. The line is a cut to length so it has to start at zero. It can do this when the cutter is fired. Thanks. Peter. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted May 2, 2018 MVP 2021 Report Share Posted May 2, 2018 In the Hardware config section (under View) for the controller, have you noticed the High Speed Inputs (Reload) section? Join the dots with the info in Help under Immediate: Update High-speed Input. I think that will likely help to solve your headtwisting! cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted May 3, 2018 MVP 2021 Report Share Posted May 3, 2018 Have you tried storing a 0 to the ML you have the encoder mapped to? Joe T. Quote Link to comment Share on other sites More sharing options...
peter leeming Posted May 3, 2018 Author Report Share Posted May 3, 2018 Think I have got it sussed. I like these self contained units. I have never used them before. I will use them again for small applications. Thank you all. No doubt I will be calling on your expertise again in the future. Thank you all Peter. Quote Link to comment Share on other sites More sharing options...
