Haris Posted August 15, 2019 Report Share Posted August 15, 2019 Hi everyone, I am trying to download my project to my Jazz JZ20-R31 PLC from U90Ladder. When I go to Controller -> M90 OPLC Settings, I click "Get Version" and I do get the correct data. "Get Time & Date" works as well, and so do the other PLC -> PC functions it seems. But when I click "Set Time & Date" or "Reset" or other PC -> PLC functions including "Download", I get an error message saying: Quote Run-time error '5': Invalid procedure call or argument When I click "OK" the program closes. A colleague of mine has also installed U90Ladder following the same procedure I have, and everything went smoothly for him (we used the same PLC). This leads me to think that the problem is system-wide for me. I am using Windows 10. Thank you. Haris Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted August 15, 2019 MVP 2021 Report Share Posted August 15, 2019 Did you install using right click run as Admin, and then once installed also set the main U90Ladder .exe to run as admin as well? cheers, Aus Quote Link to comment Share on other sites More sharing options...
Haris Posted August 15, 2019 Author Report Share Posted August 15, 2019 5 minutes ago, Ausman said: Did you install using right click run as Admin, and then once installed also set the main U90Ladder .exe to run as admin as well? cheers, Aus Yes, I have done that. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted August 15, 2019 MVP 2021 Report Share Posted August 15, 2019 OK. Time for me to get Zzzzz, but in the meantime ensure your A/V isn't interfering. And wait for someone else to chime in. No doubt my subconscious will think about this all night....thanks so much!!! M$oft has an annoying habit of breaking things with W10 updates.......and your system likely got one in the last few days if you let it. Patch Tuesday. cheers, Aus 1 Quote Link to comment Share on other sites More sharing options...
Haris Posted August 15, 2019 Author Report Share Posted August 15, 2019 27 minutes ago, Ausman said: OK. Time for me to get Zzzzz, but in the meantime ensure your A/V isn't interfering. And wait for someone else to chime in. No doubt my subconscious will think about this all night....thanks so much!!! M$oft has an annoying habit of breaking things with W10 updates.......and your system likely got one in the last few days if you let it. Patch Tuesday. cheers, Aus It was the Windows update! After removing the update from Tuesday, everything works. Thank you very much! Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted August 15, 2019 MVP 2021 Report Share Posted August 15, 2019 Good, but not so good for The Creators who now have to figure out what to change, given the supposedly "critical" nature of the latest updates and you now not having them. @Saragani or @Cara Bereck Levy can perhaps advise the relevant team to look into it. It might be just your system's quirks. No doubt it will be the usual M$oft method of completely stopping some process until they figure out how to get around having a flawed process in the first place. To me it all comes back to..."If it ain't broke, don't fix it", and "Build it Right First Time". But I acknowledge that it is often hard for Non-Devious People to think along the lines of Devious ones! cheers, Aus Quote Link to comment Share on other sites More sharing options...
AlexUT Posted August 18, 2019 Report Share Posted August 18, 2019 Hi, On the 15 August we got a few complaints that customers get this run time error 5 when they are trying to download application via U90Ladder. We investigated more and found that this is an issue caused by the latest Microsoft update. In order to solve this issue until Microsoft will release new update - Please try to uninstall the update via "New installed updates" or roll back before the update. Please see below link to Microsoft update and known issues: https://support.microsoft.com/en-us/help/4512508/windows-10-update-kb4512508 *For other version of Windows Microsoft KB article number will be different. Article can be found in the below link: https://support.unitronics.com/index.php?/selfhelp/view-article/u90-ladder-and-runtime-error-5 Best Regards, 1 Quote Link to comment Share on other sites More sharing options...
AlexUT Posted August 18, 2019 Report Share Posted August 18, 2019 Hi All, Good news from Microsoft! This time you can receive announcement about new KB update. At my W7 Pro 64 bit update is next: https://support.microsoft.com/en-us/help/4517297/windows-7-update-kb4517297 If no updsate announcement received yet, usee "Check for Updates". Update may have different KB number for different OS and OS bitness (32 or 64). So use "More information"link to be sure that this KB fixed VB errors. B.R. Quote Link to comment Share on other sites More sharing options...
Interact Posted August 22, 2019 Report Share Posted August 22, 2019 I have the same problem with the "5 error". I have found the following workaround: 1. "Create a Download file" from U90 Ladder (a D90 file) 2. Use this D90 file to create an UDC file with the Download Designer 3. Use UDC file with the Download Manager to get the program into a Jazz. This works for me (although it is a bit of a hassle). Quote Link to comment Share on other sites More sharing options...
Ely Posted August 23, 2019 Report Share Posted August 23, 2019 On 8/18/2019 at 11:02 AM, AlexUT said: Good news from Microsoft! Thank you! Was loosing my mind trying to figure this out. Quote Link to comment Share on other sites More sharing options...
