gijoevaldez Posted July 2, 2020 Report Share Posted July 2, 2020 I have two units where the USB Com Ports are bad and are unable to download the program. Is there a way to Download via the MicroSD Card? Thanks, Angel V. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted July 2, 2020 MVP 2021 Report Share Posted July 2, 2020 Yes, first make sure the SD card is properly formatted using Unitronics SD Card Suite. In VisiLogic go to Project / Create Project Files... select VisiLogic Project only (that's the default), then copy the resulting file to the folder on the SD card called USER_APP. Then go into INFO Mode to download the project to the PLC. You didn't mention which model PLC you are using - I'm not 100% sure this works on every model PLC. Quote Link to comment Share on other sites More sharing options...
gijoevaldez Posted July 2, 2020 Author Report Share Posted July 2, 2020 My PLC is a V350-35-R34. How do you get into INFO mode? Thanks for your help Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted July 2, 2020 MVP 2021 Report Share Posted July 2, 2020 15 minutes ago, gijoevaldez said: How do you get into INFO mode? This is a good opportunity for you to check out the Help in Visilogic. The forum is mostly staffed by volunteers who are very helpful but also expect users to do a bit of digging on their own before they throw questions out there. Joe T. Quote Link to comment Share on other sites More sharing options...
gijoevaldez Posted July 2, 2020 Author Report Share Posted July 2, 2020 You could of said "Press and hold the screen till the INFO menu shows up" but instead you wanted to be a jerk and spell all that out. Nice.... Thank you and have a nice day. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted July 2, 2020 MVP 2021 Report Share Posted July 2, 2020 gijoe. Thanks for the comment and your eagerness to berate someone who tells you to use your own initiative and FIND OUT ABOUT SOMETHING SIMPLE FOR YOURSELF. Do you own a car? Did you read the manual to learn how to operate some things in it? Or did you ask a forum how to put fuel in the tank? Hmmmmmm. Quote Link to comment Share on other sites More sharing options...
