CobryWZL Posted November 17, 2020 Report Share Posted November 17, 2020 Hi guys, today I installed a V100-17-ET2 in my V430 and tryed to connect to the PLC through ethernet. Unfortunatly it doesnt work. In the Info Mode of the V430 -J-TA24 the card is initialized and a IP is set. Sockets are initialized as well, but it also says "No Link for Ethernet Connection" and "Link Lost, auto recovery off". I tried different cables and PCs, but it seems to be a problem on PLC side. Any Ideas? Thanks! NVM: Took the V100 out and in again and now it works....seems like a loose contact or something.... You can delete/close this topic Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted November 17, 2020 MVP 2021 Report Share Posted November 17, 2020 I'm leaving this up because it does provide some useful troubleshooting info. Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted November 17, 2020 MVP 2021 Report Share Posted November 17, 2020 The main problem with Ehternet card after installation - insert Ehternet cable to Ehternet connector! Many times i found some installations where Ethernet cable connected to Expansion connector by mistake. And no connection.... V700 - is the champion in this type of mistake. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted November 17, 2020 MVP 2021 Report Share Posted November 17, 2020 I never install any sort of card without doing an Init and Reset. I'd also pay attention to this, to ensure that you actually have SB168 set to 1 on power-up. You'll go nuts if you don't have it active. 9 hours ago, CobryWZL said: "Link Lost, auto recovery off". cheers, Aus Quote Link to comment Share on other sites More sharing options...
