Only on-off output with PID?
Hi,
 V700 with  V200-18-E3XB
Is it possible to have a PID only output at 0% or 100% and nothing in between?
I am trying to do this to prevent a hardware component from chattering when it is not ran at 100%
I see in Visilogic function block software manual it says the following
I have set the proportional band to 0 but i still notice that i am getting values in between 0 and 100 .
I've attached the project, any advice appreciated.
52.vlp
It is SLOW PWM output for PID.
Please use in FB's menu section PWM--> SCAN.
You can find in HELP how to operate PWM (0-1000 PID output=0-1000 PWM). Then your 0-100% PID output can operate ON-OFF controlled heater.
Duty Cycle for SLOW PWM must be set approx 2-40s ( for example Duty Cycle  in steps of 0.25ms  (400=1sec)) .
  • 2 weeks later...
  • 3 weeks later...
By definition, Deadband Control is fully on or fully off.  There's no in-between, and you said in your initial post that you wanted to prevent hardware chattering.
That small of a fluctuation is really quite good for deadband control.  The range from deadband control can vary from +/- 1 degree to +/- 50 degrees depending on the thermal characteristics of the system.
You can't have it both ways.  If you want more accurate control  you'll need something that can utilize a PID loop properly and apply energy to the system in an analog fashion - somewhere between 0% and 100% with a one second or faster loop update.  This is what we use solid state relays for in a heating application.
