JDGleason Posted June 6 Report Share Posted June 6 I am working on a Unitronics HMI/PLC that has not been fully programmed since new in 2014. Someone has touched it before me. I cannot establish comms with UniLogic via USB or Enet. I have tried to do my homework. Here are the facts: I can boot to UniApps – after initialization and white screen I press top right touch screen Trying to connect from Unilogic to PLC - USB and Ethernet fail to find any PLC Panel IP is 192.168.1.5 in UniApps -> network CPU is configured for 192.168.1.3 I can connect just fine with VNC client to 192.168.1.5 in UniApps -> network 192.168.1.3 CPU does not ping Installed Unilogic as administrator Device Mgr shows a com port number 6. PLC force upgrade with DOK fails – The PLC upgrade files do not match or could not be found message…. Looking at the USB with UniApps -> memory ->SD browser shows all the files in a Unistream_Files folder. I have a case into support but very unresponsive. Thank you for any insight. Quote Link to comment Share on other sites More sharing options...
dierkens Posted June 6 Report Share Posted June 6 Make sure you're using the same version number of the Unilogic program as that used in the PLC. That's where I'd start; just to make sure there aren't any version mismatch issues. Quote Link to comment Share on other sites More sharing options...
MVP 2022 kratmel Posted June 6 MVP 2022 Report Share Posted June 6 Please post software - hardware versions of this Panel and Unilogic version used for connection. I think that you have an old version of the firmware and you should first try to update it to a previous, not the latest version via previos Unilogic. As far as I understand (I may be wrong), the crypto-protection has been improved in the latest versions and this may cause incompatibility. Quote Link to comment Share on other sites More sharing options...
JDGleason Posted June 6 Author Report Share Posted June 6 Thank you for the replies. This panel is from 2014 so it's fairly dated. UniLogic V 1.33.348 recent download. Components and Software attached. Looks like the Unilogic App is 1.9.19 Quote Link to comment Share on other sites More sharing options...
JDGleason Posted June 7 Author Report Share Posted June 7 I was to resolve this by going back to the oldest available version 1.21.51. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
Saragani Posted June 8 Report Share Posted June 8 @JDGleason, @kratmel is correct. A lot of changed since 2014. 1.9 is really old, and there are a lot of bugs that were fixed since then. As far as I remember, In UniLogic /UniStream 1.29 we have changed and improved the security, login and authentication of the UniStream PLCs, and still preserving the compatibility for communicating with older PLC firmwares, so users will be able to upgrade them. If you were able to communicate with the PLC using UniLogic 1.21.51 then that's great. I still advise you to upgrade your PLC and UniLogic to the latest version.... This is because a lot of performance that has been improved, both in UniLogic and UniStream PLC, and a lot of bugs that were fixed (in both), and also a lot of features that were added to both. However, as much as I remember, you cannot directly upgrade the PLC from 1.9, or 1.21 to 1.33 Just contact support@unitronics.com and they will instruct you on how to upgrade to the latest version. I will also forward this thread to the support team, so they will be informed about it, and they will contact you (if you haven't contact them already) Quote Link to comment Share on other sites More sharing options...
hananel Posted June 8 Report Share Posted June 8 Dear JD, Since your OS version is old you need to upgrade the OS by 2 steps: 1.xx► 1.31.174 1.31.174► 1.33.348 I sent you 1.31.174 .rar file to your mail Past the .rar file in the next path next to the existing Bin file: C:\ProgramData\Unitronics\UniLogic\Upgrade\BIN then you get 2 bin option in unilogic► So first upgrade to 1.31.174, after the update finished, format the SD again and upgrade to 1.33.260 Keep me posted. Quote Link to comment Share on other sites More sharing options...
