Fernando Castro Posted October 5, 2023 Report Share Posted October 5, 2023 I did some tests, and yeah, It's the same on V570 as V700. 14 hours ago, kratmel said: That is, an already open Socket should simply change the address without closing it. This is just a hypothesis, but if the IP address was only static here, I would understand the need for a constant switching process. The Issue is not the Socket being Open, is that you need to connect the socket to a specific IP first to use Modbus OverTCP/IP. If you connect to a Device 1, then use Modbus IP function for Device 1, then you try to use another Modbus Function to Device 2 (Using the stored IP for Device 2 on the MI and selecting the correct device) then the PLC still sends the Modbus requests to Device 1. I know that because I get a response status of 7. * Messages 6, 7, and 11mean that the master has found incompatible elements in the data sent between master and slave. which makes sense because those requests don't make sense for Device 1. And based on my tests, to use connect function you should be disconnected first. already tried using connect without disconnecting first. 2 Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted October 5, 2023 MVP 2023 Report Share Posted October 5, 2023 I think you have seen this topic Maybe changing the protocol is more effective than disconnection - connection. But this is again just a hypothesis. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted October 5, 2023 MVP 2023 Report Share Posted October 5, 2023 1 hour ago, kratmel said: I think you have seen this topic And I can't believe nobody laughed at my incredibly funny joke in the last reply. 😄 Quote Link to comment Share on other sites More sharing options...
Fernando Castro Posted October 5, 2023 Report Share Posted October 5, 2023 3 hours ago, kratmel said: I think you have seen this topic Maybe changing the protocol is more effective than disconnection - connection. But this is again just a hypothesis. Seems that It Isn't. changing SB147 to 0 stops the communication but I need to re initialize the socket then to connect to Modbus TCP slaves again. Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted October 5, 2023 MVP 2023 Report Share Posted October 5, 2023 I searched the help a bit and found this (see the red box). Just what does that mean??? Quote Link to comment Share on other sites More sharing options...
Fernando Castro Posted October 6, 2023 Report Share Posted October 6, 2023 12 hours ago, kratmel said: I searched the help a bit and found this (see the red box). Just what does that mean??? I also read that, and I also got confused about it.... however, I just tried and couldn't make it work. It's even more confusing because it seems that for Modbus TCP/IP a socket connection must be stablished first ..maybe the broadcasting function works on UDP only? but again... maybe I am doing something wrong, It is a shame that there is no example using Unitronics as a master to multiple slaves. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted October 6, 2023 MVP 2023 Report Share Posted October 6, 2023 I've just asked support to get in on this topic as I think it is important. As well, re the above, is this info below the above screenshots relevant? .........To me , it is....... As I don't use Modbus IP at all, my knowledge is limited. But am following this topic with interest. cheers, Aus Quote Link to comment Share on other sites More sharing options...
Fernando Castro Posted October 7, 2023 Report Share Posted October 7, 2023 3 hours ago, Ausman said: I've just asked support to get in on this topic as I think it is important. As well, re the above, is this info below the above screenshots relevant? .........To me , it is....... As I don't use Modbus IP at all, my knowledge is limited. But am following this topic with interest. cheers, Aus I believe that that is to add the slaves to the protocol, and it means that you can't select a device which IP has not been added to the configuration FB first? I can communicate without problems, but using the same socket for many devices requires closing the connection and connecting to the other IP before sending/receiving. Quote Link to comment Share on other sites More sharing options...
Ivgeny Posted October 10, 2023 Report Share Posted October 10, 2023 Hi Fernando, Please explain your task clearly, I will try to provide you with the right answers. On 10/7/2023 at 3:43 AM, Fernando Castro said: I believe that that is to add the slaves to the protocol, and it means that you can't select a device which IP has not been added to the configuration FB first? I can communicate without problems, but using the same socket for many devices requires closing the connection and connecting to the other IP before sending/receiving. Quote Link to comment Share on other sites More sharing options...
Fernando Castro Posted October 12, 2023 Report Share Posted October 12, 2023 On 10/10/2023 at 1:09 AM, Ivgeny said: Hi Fernando, Please explain your task clearly, I will try to provide you with the right answers. It's a straightforward application: Use a Unitronics Vision PLC as Modbus TCP/IP Master, communicating with many slave devices at the same time (let's say minimum 2 maximum 4) with low latency, using only one single socket (All other sockets are being used for different applications). One of the Modbus slaves was supposed to control a process variable linked to the output of a PID loop in the PLC. BTW, at this point for me, it's only out of my curiosity, the company I worked for has filed for bankruptcy and I was laid off, so I cannot test anything, well... I guess I could (assuming I have some remote connection to the facility still enabled and all my test equipment is still on 😏) but of course that will be illegal. 😅 Quote Link to comment Share on other sites More sharing options...
Fernando Castro Posted October 18, 2023 Report Share Posted October 18, 2023 @Ivgeny is this possible with vision series or not? Quote Link to comment Share on other sites More sharing options...
