micapp Posted August 26 Report Share Posted August 26 Visilogic stopped abnormally and will not start. Screendump enclosed. I try to uninstall Visilogic but get error here also (enclosed screendump Any solution? Quote Link to comment Share on other sites More sharing options...
MVP 2022 kratmel Posted August 26 MVP 2022 Report Share Posted August 26 also read https://support.unitronics.com/index.php?/selfhelp/view-article/Catastrophic-Failure---Visilogic Quote Link to comment Share on other sites More sharing options...
MVP 2022 Ausman Posted August 26 MVP 2022 Report Share Posted August 26 As well as Kratmel's suggestion, the "91" error is the classic one that comes up without install and run as Admin. See here: https://forum.unitronics.com/topic/7917-visilogic-doesnt-work-properly-after-installation-what-install-as-administrator-really-means/ Quote Link to comment Share on other sites More sharing options...
micapp Posted September 19 Author Report Share Posted September 19 Solved! Thanks kratmel Quote Link to comment Share on other sites More sharing options...
