Cara Bereck Levy Posted December 14, 2023 Report Share Posted December 14, 2023 Your security is our priority, and we are pleased to announce the release of VisiLogic version 9.9.00. This version focuses on enhancing and strengthening the protection of your automation systems. It requires you to change default passwords and implement complex passwords and comprises new features to protect Vision and Samba controllers. These features include mandatory password protection for PCOM communications via Ethernet, a method enabling you to block remote access actions initiated via PCOM, and a way to change the Information Mode default password via Ladder. Unitronics strongly recommends that users with existing applications comprising Vision and Samba controllers that are connected to the internet, update to the current VisiLogic and firmware version, as well as to updated versions of Unitronics’ compatible utilities. In addition to securing Device Level security by using the features included in this new VisiLogic version, implementing effective system security requires a layered approach. While upgrading to this version enhances device security, network protection is essential as your first line of defense. It is highly important to make sure that any internet connection will be done using firewalls to restrict unwanted access and that there are no port forwarding settings exposing automation equipment directly to the public network. Upgrade Now for Enhanced Security We highly recommend updating to VisiLogic 9.9.00 to benefit from the latest security enhancements and ensure the protection of your critical industrial systems. The new version is available on our site: https://www.unitronicsplc.com/software-visilogic-for-programmable-controllers/ * For UniCloud customers: please contact us for specific guidance. For detailed instructions on upgrading and implementing the recommended security measures, please Click Here or contact directly to our technical support team. 1 Link to comment Share on other sites More sharing options...
ZebioEE Posted December 14, 2023 Report Share Posted December 14, 2023 Hello, Thanks for security updates. Another big problem still exist is PLC trying going to Info mode while remotely controlled if client push and hold screen. Then client see INFO MODE not supprted and randomly push screen and cannot go out due PLC asking password but not showing it and not react to Esc button. Please update software to block PLC going to info mode remotely absolutely. Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 14, 2023 MVP 2023 Report Share Posted December 14, 2023 8 minutes ago, ZebioEE said: Please update software to block PLC going to info mode remotely absolutely. You can already do that: assign a power-up of zero to SI 50. Link to comment Share on other sites More sharing options...
ZebioEE Posted December 15, 2023 Report Share Posted December 15, 2023 But need block PLC going to info mode remotely ! If set zero SI 50 it not possible go info mode physically. Need someway link SI 50 with remotes. Link to comment Share on other sites More sharing options...
ZebioEE Posted December 15, 2023 Report Share Posted December 15, 2023 Is the any SI, SB pop up while remote sessions are Active ? Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 15, 2023 MVP 2023 Report Share Posted December 15, 2023 4 hours ago, ZebioEE said: But need block PLC going to info mode remotely ! If set zero SI 50 it not possible go info mode physically. Need someway link SI 50 with remotes. Require a password to change the value of SI 50 or password protect a button for SB 36, or place the button on a screen not accessible remotely. Link to comment Share on other sites More sharing options...
ZebioEE Posted December 15, 2023 Report Share Posted December 15, 2023 42 minutes ago, Flex727 said: Require a password to change the value of SI 50 or password protect a button for SB 36, or place the button on a screen not accessible remotely. Is exist an SB 140 -Remote access - read only, but it not react to remote session. Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 15, 2023 MVP 2023 Report Share Posted December 15, 2023 When you say "remote session", what are you referring to specifically? Link to comment Share on other sites More sharing options...
ZebioEE Posted December 15, 2023 Report Share Posted December 15, 2023 35 minutes ago, Flex727 said: When you say "remote session", what are you referring to specifically? I mean when cosumer connected PLC using phone APP or another remote access program. PLC firmare is detect remote session and showing confusing message screen instead just block any try go to info mode. If SB 140 will show remote session then can be write zero to SI 50 to block " confusing message screen" and restore value 4 when session finished. SB 36 - also have strange behave can set 1 by program (info screen pop-up) but cannot be creared, only physically need press Esc- Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted December 17, 2023 Author Report Share Posted December 17, 2023 On 12/15/2023 at 6:13 PM, ZebioEE said: I mean when cosumer connected PLC using phone APP or another remote access program. PLC firmare is detect remote session and showing confusing message screen instead just block any try go to info mode. If SB 140 will show remote session then can be write zero to SI 50 to block " confusing message screen" and restore value 4 when session finished. SB 36 - also have strange behave can set 1 by program (info screen pop-up) but cannot be creared, only physically need press Esc- @ZebioEE, your comments have been forwarded to the team and we are looking into them--thanks for posting. 1 Link to comment Share on other sites More sharing options...
ZebioEE Posted December 19, 2023 Report Share Posted December 19, 2023 Another issue pop up with new operating system! When updating PLC with new OS it erasing all data (initialize - reset) , with previously updated OS was not erasing . Why this happens? How to avoid erasing data with OS updates? Link to comment Share on other sites More sharing options...
DanT Posted December 19, 2023 Report Share Posted December 19, 2023 Hi; Memory Values can be backed up Do this Before working with the OS From VisiLogic: Connection -- lower section - Just above communication and US Export PLC Operands to Text file or Export PLC Operands to Binary file. Then do the reverse -- Import the values back in DanT Link to comment Share on other sites More sharing options...
ZebioEE Posted December 19, 2023 Report Share Posted December 19, 2023 49 minutes ago, DanT said: Hi; Memory Values can be backed up Do this Before working with the OS From VisiLogic: Connection -- lower section - Just above communication and US Export PLC Operands to Text file or Export PLC Operands to Binary file. Then do the reverse -- Import the values back in DanT Thanks DanT Is not help unfortunately for remote OS updates. Because new OS eraising all MI and also network parameter's, then PLC system restart with all zero and you cannot connect it due PLC name , IP etc. all zeroes and no possible restore parameters just for reason unable to connection. With previously OS updates was never eraising parameters, I'm using Unictonics PLC ~15Years and first time this issue popped up. If you can physically make updates then is can set up back, but I have many abroad system's and canot update without on site helps what is very inconvenient due most consumers is end users and not PLC geek . Also is looking unprofessional. Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted January 21 Author Report Share Posted January 21 On 12/14/2023 at 7:28 PM, ZebioEE said: Another big problem still exist is PLC trying going to Info mode while remotely controlled if client push and hold screen. Then client see INFO MODE not supprted and randomly push screen and cannot go out due PLC asking password but not showing it and not react to Esc button. Please update software to block PLC going to info mode remotely absolutely. Hi @ZebioEE Thanks for posting. This issue is fixed in OS 4.12.46; please try it and let us know if you have any difficulties. 1 Link to comment Share on other sites More sharing options...
ZebioEE Posted January 22 Report Share Posted January 22 Hello Cara, Thanks for update. How to get new updated OS ? 1 Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted February 11 Author Report Share Posted February 11 Hi--sorry for the lag in answering! It is included with the most recent VisiLogic release. You can also update the OS's via Live Update from the Web. Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted February 11 MVP 2023 Report Share Posted February 11 10 hours ago, Cara Bereck Levy said: Hi--sorry for the lag in answering! I think we can cut you some slack. You've been...busy. Link to comment Share on other sites More sharing options...
Bisku Posted February 13 Report Share Posted February 13 On 2/11/2024 at 8:53 AM, Cara Bereck Levy said: Hi--sorry for the lag in answering! It is included with the most recent VisiLogic release. You can also update the OS's via Live Update from the Web. Mmh,I already tried that. The most recent version I can find on Unitronics' website is VisiLogic 9.9.0 Build 0, which offers OS 4.12 (38) only. And I also already tried the search for online updates as you mentioned. But as of today Live Update fails. It says there are no updates available. Maybe you can support us by posting the .uos-file here? Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted February 15 Author Report Share Posted February 15 On 2/13/2024 at 9:49 PM, Bisku said: Mmh,I already tried that. The most recent version I can find on Unitronics' website is VisiLogic 9.9.0 Build 0, which offers OS 4.12 (38) only. And I also already tried the search for online updates as you mentioned. But as of today Live Update fails. It says there are no updates available. Maybe you can support us by posting the .uos-file here? I will talk to support. 1 Link to comment Share on other sites More sharing options...
