Milosh Posted July 4, 2020 Report Share Posted July 4, 2020 Hi all. I have problem with one v430. When try to download programm this message appears: ...ethernet card not supported by this OS version... VisiLogic version 9.6... Same program installed on 3 of 4 PLCs...only with one PLC I have problem... Quote Link to comment Share on other sites More sharing options...
Milosh Posted July 4, 2020 Author Report Share Posted July 4, 2020 This is the message which appears... I tried with older OS, but then also have another error message... Quote Link to comment Share on other sites More sharing options...
Milosh Posted July 4, 2020 Author Report Share Posted July 4, 2020 When I go to info mode ->Ethernet No Ethernet card Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted July 4, 2020 MVP 2023 Report Share Posted July 4, 2020 Update the O/S (firmware) in the PLC. The instructions on how to do that are in the error message you posted. Quote Link to comment Share on other sites More sharing options...
Milosh Posted July 4, 2020 Author Report Share Posted July 4, 2020 1 hour ago, Flex727 said: Update the O/S (firmware) in the PLC. The instructions on how to do that are in the error message you posted. Thanks Flex. I tried with newer OS which I have and this error message appears. I suspect that maybe eth. card is damaged. If eth. card is undamaged it will shows in Info mode?! Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted July 4, 2020 MVP 2023 Report Share Posted July 4, 2020 1 hour ago, Milosh said: I suspect that maybe eth. card is damaged. First thing I would do is remove the Ethernet card and inspect the pins carefully, then replace it carefully and fully and see if there is any change. If not, you might replace the card - they are not expensive. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted July 5, 2020 MVP 2023 Report Share Posted July 5, 2020 On 7/4/2020 at 3:57 AM, Milosh said: Same program installed on 3 of 4 PLCs...only with one PLC I have problem... I'd start swapping parts with the other PLCs to find the problem child. Joe T. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted July 5, 2020 MVP 2023 Report Share Posted July 5, 2020 Everything said already is perfectly valid. Flex suggested O/S, but I'd also be starting from absolute scratch on the affected plc. It appears it is recognising the card is there, but saying it can't work it. Delete everything via info mode, then reload boot, O/S etc, then try to load a completely empty program. I'm thinking a crook part, but try the unit's brain surgery first. cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted July 5, 2020 MVP 2023 Report Share Posted July 5, 2020 Hi, is it possible that simple com port card installed (not Ethernet) in the same slot? P.S. I found sometimes ethernet connected to the extension port :) Quote Link to comment Share on other sites More sharing options...
AlexUT Posted July 6, 2020 Report Share Posted July 6, 2020 On 7/4/2020 at 7:10 PM, Milosh said: When I go to info mode ->Ethernet No Ethernet card Ethernet Card not detected - how it will be initialized and used? SB 141 - Ethernet Card Exists Carefully inspect Ethernet Card connector and installation slot. Check this Ethernet Card at other PLC, as already recommended. Quote Link to comment Share on other sites More sharing options...
