alpha Posted November 20, 2010 Report Share Posted November 20, 2010 Hi, I tried updating the OS in my three or four year old V570 and the screen went black and now cannot communicate with it. I have removed the battery and cycled power with finger on the screen, touching it once again, and still cannot communicate with it. I was using Visilogic V8.0.1, and now have updated to 8.6.3, but still have the same problem. If I cycle the power on the unit it starts beeping until I touch the screen. That is the only sign of life it gives me. Has anyone had any similar experience. Regards, Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted November 21, 2010 MVP 2014 Report Share Posted November 21, 2010 How long did you leave the unit powered down with the battery removed? It seems to take 30mins or so to be sure all residual charge is lost. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted November 22, 2010 MVP 2021 Report Share Posted November 22, 2010 For starters, manually set your baud rate to 115200 and try to connect. Joe T. 1 Quote Link to comment Share on other sites More sharing options...
Jas Posted November 23, 2010 Report Share Posted November 23, 2010 If the firmware ever becomes corrupted or you receive a blank beeping screen, the instructions below will fix the problem 99% of the time. Please put the controller into bootstrap mode and then follow the instructions below for manually reinstalling in “advanced†mode the firmware on the controller. Be certain to use the max baud rate of 115,200 and physical port 1 of the PLC. To Enter Bootstrap Mode: With the power to the PLC turned off, hold your finger down on the touch screen and plug the power in. With your finger still pressed down count for five seconds, then release and tap the screen twice. Try individually installing first just the Bin Lib, then just the Boot, then just the O/S all while in bootstrap mode. In between each step VisiLogic will ask if you want to send a run command, select no each time. After going through this three step process of Bin, Boot, O/S normal operation should be restored. Quote Link to comment Share on other sites More sharing options...
tester2 Posted November 24, 2010 Report Share Posted November 24, 2010 I had the same problem with black screen. it seems to be the software to update the v570 that has some kind of bug. becouse i used 2hours to get my unit back to life. i had to change computer 3 times to get the unit back to life. the other 2 computers have same setup and always give me checksum error of some kind. i think unitronics have to work on a better solutions for firmware upgrade since upgrading this unit is a risky choice. i allways had problem upgrade firmware and have to try many times before i success without any error. this unit is 2years old. so i would like to have an answer from unitronics on this problem. product is very good but firmware upgrade on this units is a risky bussiness. Quote Link to comment Share on other sites More sharing options...
External Moderators Nacho Posted November 12, 2012 External Moderators Report Share Posted November 12, 2012 I had a V570-57-T40B with this problem. I follow step by step the download of of Bin, Boot, O/S but the download of the O/S freezes at beginning. Is the solution to try with an older version of Visilogic? I have Windows 7 64bits with real serial port (no converter) and Visilogic 9.4.0 with the updated O/S Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted November 13, 2012 Report Share Posted November 13, 2012 Hi Nacho, Can you try to download the O/S via build in RS232 115200 baud rate from other PC? Quote Link to comment Share on other sites More sharing options...
External Moderators Nacho Posted November 13, 2012 External Moderators Report Share Posted November 13, 2012 Hi Reuven, I have tried with two PCs with build in RS232 115200 baud rate. one laptop with Windows 7 64bit and one old Personal Computer with Windows XP. I have to try with Unidownloader. Anyway, this V570 is one of the first V570 with the hide USB and SD card reader. Do you have the perfect combination of bil lib, root and o/s for this unit?? Quote Link to comment Share on other sites More sharing options...
External Moderators Nacho Posted November 15, 2012 External Moderators Report Share Posted November 15, 2012 I have tried with Unidownloader. Downloading the O/S the graphic bar freezes: After a lot of time this error appear: What is the problem? an error of hardware? This unit is old but it was in stock no in use. Quote Link to comment Share on other sites More sharing options...
External Moderators Nacho Posted June 25, 2013 External Moderators Report Share Posted June 25, 2013 At the end we sent the V570 to factory. Quote Link to comment Share on other sites More sharing options...
