tsiz Posted September 3, 2015 Report Share Posted September 3, 2015 Hello, I am new in PLC programming so my question might be funny. I have a laptop with an installed Win 7 (64bit) and installed VisioLogic ver. 9.60.7 When I make the hardware configuration of a new project in the list of supported devices is not PLC V350-35-TU24. is it possible without reinstalling the Windows software to load this type of PLC in the list of software supported ones. Thanks in advance Sergey Quote Link to comment Share on other sites More sharing options...
Alexander Posted September 8, 2015 Report Share Posted September 8, 2015 Where did you purchase the unit from, it should have the model number on the side of the unit under a barcode. There is a model of controller, the V350-35-TA24, though not a TU24 that we offer. Quote Link to comment Share on other sites More sharing options...
jouko Posted February 18 Report Share Posted February 18 I have V350-35-TU24. as in https://www.unitronicsplc.com/wp-content/uploads/2017/01/V350-35-J-TU24-IG.pdf I try to get this in the element list. is TU24 now total history ?? Bought this from Klinkmann Finland. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted February 18 MVP 2021 Report Share Posted February 18 I have never seen nor heard of this model either. You might want to contact Unitronics support to see if they can help you. Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted February 18 MVP 2021 Report Share Posted February 18 Hi, this information from Unitronics support maybe helpful. Please close Visilogic. In Visilogic installation you can find this folder C:\Program Files\Unitronics\Unitronics VisiLogic_C\Data\HW Cfg\Elements List Than find in this folder file ElementsList.ini Open this file via notepad - you can find all supported Vision PLC. You can add V350-35-TU24 and save file. After that V350-35-TU24 appear in Visilogic HW Config after Visilogic start and you can use it in project. P/S V350-35-TU24.ini file for this PLC present in Visilogic installation (in HW Cfg folder) but not listed in ElementsList.ini Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted February 18 MVP 2021 Report Share Posted February 18 40 minutes ago, kratmel said: In Visilogic installation you can find this folder C:\Program Files\Unitronics\Unitronics VisiLogic_C\Data\HW Cfg\Elements List Don't forget it might be in Program Files (x86), depending on your computer's OS. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted February 18 MVP 2021 Report Share Posted February 18 and @Cara Bereck Levy ....is this perhaps a thing that shouldn't need to be done by users? ⛔ !! cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted February 19 MVP 2021 Report Share Posted February 19 21 hours ago, kratmel said: Open this file via notepad - you can find all supported Vision PLC. You can add V350-35-TU24 and save file. After that V350-35-TU24 appear in Visilogic HW Config after Visilogic start and you can use it in project. How does this tell VisiLogic what the available I/O is? Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted February 19 MVP 2021 Report Share Posted February 19 22 hours ago, kratmel said: V350-35-TU24.ini file inside Visilogic HW Cfg folder. In this file you can see IO configuration for this PLC. You can also find IO configuration for all posible PLC in ini files. In ElementsList.ini file present list off *.ini files in HW Cfg folder (but some PLC variant is not listed). V130-35-TU24.ini not present also Quote Link to comment Share on other sites More sharing options...
