KevB Posted April 29, 2020 Report Share Posted April 29, 2020 i, I have lost communication with the USC-B-TR22 I am using and seem unable to re-establish it. I had the IP addr set to 192.168.0.64 for the panel and 192.168.0.65 for the CPU, and this was working. I then compiled my first program and downloaded it to the unit, when I tried to VPN it to try it out an error appeared, 'incorrect IP address'. I checked all the IP addresses and noticed they had both changed so I put them back to the above address but could not get comms. I set them to the default values but no difference. The program was just a simple one, as I am trying to teach myself, on the HMI I put a button and an indicator, when the button is pushed DO0 changes state and the indicator monitors DI0 for that change in state. I am not too worried about the program as yet just the communication issue, any help much appreciated. KevB Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted April 29, 2020 MVP 2021 Report Share Posted April 29, 2020 Moved to the correct forum. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted April 29, 2020 Report Share Posted April 29, 2020 Hi KevB, What do you mean by saying " when I tried to VPN it to try it out"? What are network settings for PLC, VPN, PC? B.R. Quote Link to comment Share on other sites More sharing options...
KevB Posted April 30, 2020 Author Report Share Posted April 30, 2020 Hi AlexUT, I have tried to check what I meant, but I can't find anything VPN I may have been confused with another project I am doing, I currently have the PC and PLC set to address 192.168.1.4 and the PLC cpu set to 192.168.1.5 with the Subnet mask 255.255.255.0 and the default gateway to 192.168.1.1. When I originally had communication the ip address for both was 192.168.0.64 and .65 not 100% sure on the gateway but I think it was 192.168.0.1. KevB Quote Link to comment Share on other sites More sharing options...
AlexUT Posted April 30, 2020 Report Share Posted April 30, 2020 " I currently have the PC and PLC set to address 192.168.1.4" confuse me. What is PC configuration? Do you use any router with DHCP settings? How it configured? Or you use LAN Switch? *You cannot assign the same IP address to 2 devices at the same LAN. It will not work. Quote Link to comment Share on other sites More sharing options...
KevB Posted April 30, 2020 Author Report Share Posted April 30, 2020 So I have just checked what each is set to, the computer is set to IP 192.168.0.60, and the PLC Panel 192.168.0.64 and the PLC CPU 192.168.0.65. The Subnet mask and default gateway are all set to 255.255.255.0 and 192.168.0.1 respectively, the PLC is connected directly to a small form factor ACEPC via a straight through Cat 6 cable. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted April 30, 2020 MVP 2021 Report Share Posted April 30, 2020 4 hours ago, KevB said: the PLC is connected directly to a small form factor ACEPC via a straight through Cat 6 cable. Try a crossover cable or get an Ethernet hub or switch. Can you Ping the PLC from the PC? Quote Link to comment Share on other sites More sharing options...
KevB Posted April 30, 2020 Author Report Share Posted April 30, 2020 The crossover cable didn't work, and the ping said the target was unreachable, with both cables. I don't think it would be the cable as it was working until I tried to download a file to the PLC. I am going to start again from the beginning and see if that works.....! clutching at straws now KevB Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted April 30, 2020 MVP 2021 Report Share Posted April 30, 2020 Does your PC have both a wired Ethernet connection and WiFi? If so, it's easy to confuse the two settings and get the subnet wrong. Make sure your PC's WIRED Ethernet connection is on subnet 192.168.0.xxx. Quote Link to comment Share on other sites More sharing options...
KevB Posted April 30, 2020 Author Report Share Posted April 30, 2020 I have done that, I tried starting a new project but that isn't working either. I am not sure if the address was set correctly when I downloaded my program and from reading different posts, might that mean I have to reset my PLC? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted April 30, 2020 MVP 2021 Report Share Posted April 30, 2020 You can check the PLC Ethernet address in UniApps (touch and hold the upper right corner of the PLC screen). Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted April 30, 2020 MVP 2021 Report Share Posted April 30, 2020 Let's go to a lower level. Are you able to download the program via the USB cable? If you can attach the program to a post we can have a look at your configuration. Joe T. Quote Link to comment Share on other sites More sharing options...
KevB Posted May 1, 2020 Author Report Share Posted May 1, 2020 15 hours ago, Flex727 said: You can check the PLC Ethernet address in UniApps (touch and hold the upper right corner of the PLC screen). I don't have a screen attached to the PLC it is being used through a PC. 8 hours ago, Joe Tauser said: Let's go to a lower level. Are you able to download the program via the USB cable? If you can attach the program to a post we can have a look at your configuration. Joe T. I have just got a USB cable and tried to download using it but it doesn't see the PLC. I have attached the small program I have done just to teach myself. Thanks again for your help. KevB lesson.ulpr Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted May 1, 2020 MVP 2021 Report Share Posted May 1, 2020 Please see in this menu Project/Option Default Unilogic settings downloaded to you PLC when you try to download project. This is my settings. You maybe see another numbers... Quote Link to comment Share on other sites More sharing options...
KevB Posted May 4, 2020 Author Report Share Posted May 4, 2020 Hi all, thanks for all the help, the unit started communicating on USB this morning, then stopped ? I went back to using the ethernet reset all the addresses back to what I was using and now it is communicating fine. My program isn't running but it has shown me the errors so I am going to work through them. Thanks again for your help I am sure you will hear from me again. KevB Quote Link to comment Share on other sites More sharing options...
