guusminnaard Posted December 6, 2022 Report Share Posted December 6, 2022 I want to put in an program with the latest software, when i try the system tells me its not possible because the os in my plc is to old when i want to update the system it doesn't work. The program has 4.8(10) os. How do i solve the problem? Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted December 6, 2022 Report Share Posted December 6, 2022 Install the version of Visilogic originally used to program the PLC. To find out what version it is, open the vlp file, go to view | signature log menu. If you definitely want to use the latest version, you must upgrade the OS before downloading the application. I do not recommend this option. Quote Link to comment Share on other sites More sharing options...
DanT Posted December 6, 2022 Report Share Posted December 6, 2022 Hi ; What is the PLC Model? Do you know what version of VisiLogic was used to program the PLC? Older Versions are still available for download and use. If you do not know what version was used. Get the OS Information from Info Mode, or Connection - Get OPLC Information Ask Support@Unitroncisplc.com what Version of VisiLogic was probably used. - obtain it and install it. Modify the program ( Original that you worked from -- NOT the new one you just did - will not be compatible) DanT Quote Link to comment Share on other sites More sharing options...
micapp Posted December 6, 2022 Report Share Posted December 6, 2022 You can download new OS under Connection - Install operating system Run Check. If the OS must be installed you will be guided in this window. You do not need to download anything else Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted December 6, 2022 MVP 2021 Report Share Posted December 6, 2022 Guus, my take on your post is that you got to the point shown by Micapp, and then the procedure failed. Is this correct? Take note of everything everyone else has said already, and please answer the questions asked. I have experienced issues that I haven't had time to resolve, with Windows versions upsetting the ability for the os update to run properly on my main PC. Points to note on this: 1). Depending on your plc model, to do the update you will likely be needing to be online through port 1, with the grey MJ10-22-CS25 cable linking the PC to the plc. At present the only way I can do this is with my W7 laptop that runs a dedicated serial port. Note that my main PC on W10 does have a native serial port, but Windows has done something to break the OS update process which used to be OK. 2). If you are using a USB to serial adapter, it must be a Prolific chip. One based on the FTDI chip does not work properly for some reason. Have a read of this topic. I don't know if the very last comment works or not. https://forum.unitronics.com/topic/500-updating-oplc-os-bin-lib-file-boot-file/?do=findComment&comment=2003 cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted December 6, 2022 MVP 2021 Report Share Posted December 6, 2022 There's another option - that I haven't personally tried, but should work - is to create a CLONE file on an SD card using VisiLogic and the correct firmware associated with that version of VisiLogic. Then load the clone on the PLC via INFO Mode. The PLC should then have the latest firmware and the program loaded. Of course, the OP has never volunteered the PLC model, so it may not have an SD card slot. Quote Link to comment Share on other sites More sharing options...
guusminnaard Posted December 7, 2022 Author Report Share Posted December 7, 2022 All right, i did some version swaps and now its working its really crazy, i know Right now i got os 4.11 (02) Quote Link to comment Share on other sites More sharing options...
