micapp Posted March 25 Report Share Posted March 25 See enclosed picture. Is this correct use of analog input? And on second picture: Is this the correct use of analog output? Quote Link to comment Share on other sites More sharing options...
MVP 2022 Flex727 Posted March 25 MVP 2022 Report Share Posted March 25 Unitronics has excellent online technical manuals. Information about your module can be found here:https://downloads.unitronics.com/Documents/UniStream_IO_%26_COM/UniStream_Remote_I_O_User_Manual.pdf Quote Link to comment Share on other sites More sharing options...
micapp Posted March 25 Author Report Share Posted March 25 57 minutes ago, Flex727 said: Unitronics has excellent online technical manuals. Information about your module can be found here:https://downloads.unitronics.com/Documents/UniStream_IO_%26_COM/UniStream_Remote_I_O_User_Manual.pdf Not so easy to understand. No information on sink or source on analog units. And there is lso a error in one of the descritions as far as I can understand Quote Link to comment Share on other sites More sharing options...
micapp Posted March 25 Author Report Share Posted March 25 This is what I think is wrong: Quote Link to comment Share on other sites More sharing options...
micapp Posted March 25 Author Report Share Posted March 25 nd this is what i find difficult to understand. Normally I connect my two-wire sensor to + 24V and i.e. input CH1 (on picture), but this looks like the sensor shall connect +24V to CH1 and the low side to 0V ? Quote Link to comment Share on other sites More sharing options...
MVP 2022 Flex727 Posted March 25 MVP 2022 Report Share Posted March 25 @Cara Bereck Levycould you take a look at this? Quote Link to comment Share on other sites More sharing options...
MVP 2022 Joe Tauser Posted March 25 MVP 2022 Report Share Posted March 25 13 hours ago, micapp said: See enclosed picture. Is this correct use of analog input? And on second picture: Is this the correct use of analog output? Yes* and yes. The manual is clearly wrong. The Ethernet I/O is not a Unitronics-manufactured product, and the manual is not an original complete creation of the Unitronics documentation department. It is a modified re-issue of what the manufacturer supplied. So somebody missed something. Too many late nights and deadlines on the tech writers, I would suspect. Thanks for pointing this out. Flex has already flagged Cara Levy the Documentation Queen so hopefully it gets corrected and updated soon. Joe T. * - that is correct for a two-wire device. Some devices require separate power and generate their own current rather than modulating their supply. Quote Link to comment Share on other sites More sharing options...
Pavel_setnicar Posted March 26 Report Share Posted March 26 19 hours ago, micapp said: nd this is what i find difficult to understand. Normally I connect my two-wire sensor to + 24V and i.e. input CH1 (on picture), but this looks like the sensor shall connect +24V to CH1 and the low side to 0V ? I think this is about analog OUTPUT , and it is corect . Quote Link to comment Share on other sites More sharing options...
