vlader Posted July 17 Report Share Posted July 17 Hello! There was a problem with the program, everything was fine earlier. The problem is related to the fact that saved projects are not opened and a new project is not saved. The Windows 10 Pro version is 22H2, Remote operator v. 1.0.78. I tried switching the use of NET 3.5 to NET 4.8 as described here: The solution didn't work. Since that time, there have been more options to solve this problem? Remote Access also cannot load the project by issuing the error: "Run-time error'5': Invalid procedure call or argument" Quote Link to comment Share on other sites More sharing options...
AlexUT Posted July 17 Report Share Posted July 17 Hi, Problem may be a result of Windows Update. Update may change access rights to directories you use. Please contact your IT to solve this problem. *To prove this, open Notepad, enter any text and attempt to save file where you wish to save Remote Access files. If Windows show error - your IT have to enable write rights to this directory. B.R. Quote Link to comment Share on other sites More sharing options...
vlader Posted July 17 Author Report Share Posted July 17 Updates have not been installed for a long time, I tried to save them in different places. At the same time, the file is created. Now I checked on another computer, the saved project opens with the correct settings. But when saving, an error occurs and the saved project does not open, but still writes "untitled" in the header. Other projects also do not open. Quote Link to comment Share on other sites More sharing options...
MVP 2022 Flex727 Posted July 17 MVP 2022 Report Share Posted July 17 Are you saving the file to a local hard drive or to a networked drive? Quote Link to comment Share on other sites More sharing options...
vlader Posted July 17 Author Report Share Posted July 17 local hard drive Quote Link to comment Share on other sites More sharing options...
vlader Posted July 18 Author Report Share Posted July 18 I also started remote operator on behalf of the administrator in order to overcome possible rights problems Quote Link to comment Share on other sites More sharing options...
vlader Posted July 25 Author Report Share Posted July 25 Are there any other options to solve the problem? Quote Link to comment Share on other sites More sharing options...
MVP 2022 Joe Tauser Posted July 25 MVP 2022 Report Share Posted July 25 Try uninstalling Remote Operator with Revo Uninstaller and doing a fresh install. Be sure to run the install as Administrator. Joe T. Quote Link to comment Share on other sites More sharing options...
vlader Posted July 25 Author Report Share Posted July 25 Solution didn't help Quote Link to comment Share on other sites More sharing options...
MVP 2022 Ausman Posted July 25 MVP 2022 Report Share Posted July 25 Have you checked the security settings of the relevant folders to ensure you still have full rights? On 7/18/2023 at 4:30 PM, vlader said: I also started remote operator on behalf of the administrator This is not the same as installing as admin, that's why Joe has mentioned it. See here, and ensure all equivalent steps are done, given you are working with Remote Op instead of Visi. The error messages do sound like it hasn't been installed as admin. https://forum.unitronics.com/topic/7917-visilogic-doesnt-work-properly-after-installation-what-install-as-administrator-really-means/ 1 Quote Link to comment Share on other sites More sharing options...
vlader Posted July 26 Author Report Share Posted July 26 Thanks! It worked. Deleted with a complete registry cleanup. Quote Link to comment Share on other sites More sharing options...
MVP 2022 Joe Tauser Posted July 26 MVP 2022 Report Share Posted July 26 On 7/25/2023 at 1:49 AM, vlader said: Solution didn't help So.... did you use Revo Unistaller when you posted this or just the Windows uninstaller? Joe T. Quote Link to comment Share on other sites More sharing options...
vlader Posted July 26 Author Report Share Posted July 26 Revo uninstaller. Windows uninstaller did not help Quote Link to comment Share on other sites More sharing options...
