cbryan 0 Posted January 7 Report Share Posted January 7 I just found this in the Visilogic change log and got exited. I finally see the release of a unitronics branded load cell module compatible with Uni-Stream without using CanBus. Of course the project is already done, but all projects are just the start of an evolution. Since I only have two machines loose in the world with this hardware configuration I'd be more than happy to make the change now. So when can I get my hands on at a minimum the documentation for URS-02LC-8 ? I'd like it yesterday if possible. Quote Link to post Share on other sites
Ausman 202 Posted January 7 Report Share Posted January 7 3 hours ago, cbryan said: got exited I am assuming that this is missing a "c". 🙂 I was a little confused at first! A search at the main site didn't pick anything up. @Cara Bereck Levy ?? cheers, Aus Quote Link to post Share on other sites
cbryan 0 Posted January 8 Author Report Share Posted January 8 See I was so excited I skipped the grammar check. ( not that grammar or spelling is something I do well to begin with. ) https://www.unitronicsplc.com/io-expansion-modules/ NEW - UniStream Remote I/O - Expand over Ethernet // Its the last item for inputs. URS-02LC-8 Aside from being on this page and mentioned in the change log for the Visilogic 9.8.91 it is no where to be found. I searched the knowledge base as well and all that comes up is UL listings. Quote Link to post Share on other sites
sgull 13 Posted January 8 Report Share Posted January 8 Hi I think the unit is listed in the remote I/O user manual. Try this link https://www.unitronicsplc.com/wp-content/uploads/2020/06/UniStream-Remote-I-O-User-Manual.pdf Quote Link to post Share on other sites
cbryan 0 Posted January 8 Author Report Share Posted January 8 Thank you! That's prefect. Quote Link to post Share on other sites
Ausman 202 Posted January 8 Report Share Posted January 8 Thanks Denis. Yes...that's prefect! 🙂 Quote Link to post Share on other sites
