MVP 2021 Flex727 Posted August 10, 2022 MVP 2021 Report Share Posted August 10, 2022 Anyone ever noticed the lovely eyeglasses column in the Linearization FB? What is the secret to getting that column populated when online with the PLC? If you're online, the FB can't be opened, and when the FB is open, you can't go online. Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted August 10, 2022 MVP 2021 Report Share Posted August 10, 2022 I think that everything is much simpler. Programming the environment itself without this column broke the state of affairs in mutual copy operations. The fact that there are glasses here is not a disadvantage. I usually put the variables in linearizations in numbering order and see them online below in the operands. P.S. More recently, in one of forum topic, I discovered that in Data Tables, you can store not one variable, but several in each record. It was helpful. However, this violates the state of affairs with copying and does not allow importing - exporting data tables to Excel. Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted August 10, 2022 Report Share Posted August 10, 2022 Some other FB also have it: Modbus config, PID config, Events. I´ve found it useful when tunning PIDs Quote Link to comment Share on other sites More sharing options...
sgull Posted August 10, 2022 Report Share Posted August 10, 2022 Hi Flex I think if you open the FB and click on the glasses on the FB (not the normal one on the top menu), the column gets populated. Regards Denis Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted August 10, 2022 Author MVP 2021 Report Share Posted August 10, 2022 6 minutes ago, sgull said: I think if you open the FB and click on the glasses on the FB (not the normal one on the top menu), the column gets populated. Gee, you would think I might have thought of that! Thanks, @sgull Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted August 11, 2022 MVP 2021 Report Share Posted August 11, 2022 On first reading Flex's post I was thinking I must have been missing something as I use this all the time. You can't change any of the displayed numbers, but I DO use them for checking that all variables I have running in Linz operations are working correctly, especially where I have a few that are cascaded to a final result. It's a little like using a dedicated Watch list. Another classic that shows how something can stare you in the face yet you can't see it! Quote Link to comment Share on other sites More sharing options...
