Deke Posted October 2, 2019 Report Share Posted October 2, 2019 Hi All, I'm having trouble trying to register VisiLogic, I keep getting an error something about proxy settings. Is there anyone who can help get through this? Thanks, Deke Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted October 2, 2019 MVP 2023 Report Share Posted October 2, 2019 Hi Deke, Did you use/vary the "Configure Proxy Settings" at the bottom of the rego window? Used the "Test Proxy Settings" button? Tried it as No proxy? cheers, Aus Quote Link to comment Share on other sites More sharing options...
Dejan B. Posted December 31, 2019 Report Share Posted December 31, 2019 Hi, I also have a problem with VisiLogic registering. In "Configure proxy Settings" there is an option "No proxy" and "Use system proxy settings". I tried them both, no difference, when I press "Test proxy settings" apears a message: "Connection to server failed. Proxy setings might be incorrect." For "Manual proxy configuration" I have no data. Connection to internet is of course established. Please advise. Br, Dejan Quote Link to comment Share on other sites More sharing options...
AUTOMAT-MIND Posted July 31, 2020 Report Share Posted July 31, 2020 I have the same problem to register. Does not work without PROXY, or SYSTEM PROXY. Guru, would you please give us the manual proxy settings??? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted July 31, 2020 MVP 2023 Report Share Posted July 31, 2020 Did you do the install using Right click/Run as Administrator? If not, uninstall completely and start again. After re-installation, check that the visilogic.exe is set to run as Admin as well. cheers, Aus Quote Link to comment Share on other sites More sharing options...
AUTOMAT-MIND Posted August 1, 2020 Report Share Posted August 1, 2020 Hi Aus, hello from México: Neither works. I am working windows XP, Is there any way to reset the trial period? I have removed Visilogic, and erased the file Unitronics, etc. but the period counter is still there. Last plan is to format laptop and reinstall software again. This surely reset the trial. Thanks, Arturo Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted August 1, 2020 MVP 2023 Report Share Posted August 1, 2020 VisiLogic is free. I'm not sure what happens when you don't register, but if you're having problems, sent a request to support@unitronics.com. They should be able to help you and they are usually very responsive. Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted August 1, 2020 MVP 2023 Report Share Posted August 1, 2020 I still use 9.8.65 version of Visilogic - do not registering needed, works perfect with XP. As for me stable and useful for all application where not needed UMI VFD and Servo. Yes i use latest version also - but it is installed on Win10. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted August 1, 2020 MVP 2023 Report Share Posted August 1, 2020 1 hour ago, kratmel said: I still use 9.8.65 version of Visilogic - do not registering needed, works perfect with XP. This is a great suggestion for @AUTOMAT-MIND. Quote Link to comment Share on other sites More sharing options...
visilogic_user Posted January 24, 2023 Report Share Posted January 24, 2023 I'm having trouble trying to register VisiLogic, I keep getting an error something about proxy settings. Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted January 31, 2023 MVP 2014 Report Share Posted January 31, 2023 Interestingly I also received a similar report from a customer. I advised them to uninstall Visilogic, also delete the following folders and reboot the PC before re-installing: Delete the folder “Unitronics VisiLogic_C” from C:\Program Files\Unitronics Delete the folder “Unitronics” from C:\Program Files\Common Files When re-installing, run the installer as administrator and once it is installed run Visiloigc.exe as administrator. General details on uninstalling and reinstalling are here: https://forum.unitronics.com/topic/694-how-do-i-perform-a-full-re-install-of-visilogic/ The problem was still not solved after this, they were using version 9.8.94. They then deleted all again and installed the latest (rev 9.8.96) and the registration completed successfully. I hope this helps. However if it doesn't I would also recommend the suggestion by @Flex727 above, to contact Unitronics support. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted January 31, 2023 MVP 2023 Report Share Posted January 31, 2023 I just recently installed 9.8.96 and no registration was required. Thank you, Unitronics! Quote Link to comment Share on other sites More sharing options...
Fernando Castro Posted February 6, 2023 Report Share Posted February 6, 2023 Same problem recently had a domain migration inside the company and my new windows login required the activation of visilogic.... but now the activation doesn't seem to be working, already tried uninstalling and reinstalling. ☹️ Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted February 6, 2023 MVP 2023 Report Share Posted February 6, 2023 Fernando, just curious if it works if you go completely offline during the install? Can't see how this might work, but I have had other things I use behave differently for regos if there is no WAN connection forever, or just at the time. cheers, Aus Quote Link to comment Share on other sites More sharing options...
Fernando Castro Posted February 7, 2023 Report Share Posted February 7, 2023 For those ones that may have this problem in the future, there is an offline activator. you need to send the code generated to unitronics support in order to get the licensee code to input back to Visilogic: Hi Fernando, Go to the next path and use the Offline Activator : C:\Program Files (x86)\Unitronics\Unitronics VisiLogic_C\Main\Tools\Registration\VisiLogic Offline Activator For overwriting the files, you must ensure that VisiLogic is closed, and also make sure that VisiLogic Licensing is closed from the Task Manager. Then click on the "Offline Activator.exe", this will prompt a code. 1 Quote Link to comment Share on other sites More sharing options...
Tara Posted February 13, 2023 Report Share Posted February 13, 2023 (edited) Nevermind Edited February 13, 2023 by Tara Problem solved Quote Link to comment Share on other sites More sharing options...
Fernando Castro Posted February 13, 2023 Report Share Posted February 13, 2023 4 hours ago, Tara said: Hi Fernando, this file is named Offline Activator.exe.config for me and can't be opened. And the other file named Offline Activator open a registration box who asks to complete informations. But i don't have a file that prompt a code when clicking on it. Do you have any idea of what is the problem ? is the. exe and it's that form, you complete the information, and it is going to throw a short code XXXXX-XXXXX (10 digits) which is the one that you need to send to Unitronics support so they can give you the activation code. Quote Link to comment Share on other sites More sharing options...
mr ford Posted March 2, 2023 Report Share Posted March 2, 2023 I couldn't activate under version 9.8.91. The off-line register gave me a key to send to register for the activation code, which I received, but then had no means to input that code, as the 'activate visilogic' option under 'Register' gave me only the on-line form which couldn't connect as per the proxy settings issues etc. mentioned by others above. There was then no option to proceed to the next stage to input the code I'd received. The solution was to download the latest version (9.8.96), which had no problems with the registration connecting, code issuance and completion. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted March 5, 2023 Report Share Posted March 5, 2023 On 1/24/2023 at 2:11 PM, visilogic said: I'm having trouble trying to register VisiLogic, I keep getting an error something about proxy settings. Hi, VisiLogic is a registered product name. Please change your NickName to other one. Quote Link to comment Share on other sites More sharing options...
Fernando Castro Posted March 6, 2023 Report Share Posted March 6, 2023 On 3/2/2023 at 3:38 PM, mr ford said: I couldn't activate under version 9.8.91. The off-line register gave me a key to send to register for the activation code, which I received, but then had no means to input that code, as the 'activate visilogic' option under 'Register' gave me only the on-line form which couldn't connect as per the proxy settings issues etc. mentioned by others above. There was then no option to proceed to the next stage to input the code I'd received. The solution was to download the latest version (9.8.96), which had no problems with the registration connecting, code issuance and completion. I think that once you have the code the activation park is done in visilogic on the part that says activate software license or something like that... I don't remember and since I already was able to activate it, I can no longer see that menu option. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted March 7, 2023 Report Share Posted March 7, 2023 Regarding Unitronics Software Activation - after Microsoft updates at Registration Server Security Requirements changed. VisiLogic 9.8.95 and up already updated to fit these changes. Other VisiLogic versions require offline registration. You can check if Online refistration is possible by next "work-around": - In VisiLogic open "Help->Check for Update->Operation System". If this test does not return error - online registration is possible. Best regards, Quote Link to comment Share on other sites More sharing options...
Rubens Teixeira Posted March 8, 2023 Report Share Posted March 8, 2023 Com o visilogic fechado, siga o caminho abaixo, e clique no arquivo "Offline Activator", faça o cadastro. O mesmo vai gerar uma mensagem com 10 caracteres, tire print dessa mensagem e envie para register@unitronics.com E retornarão com uma chave de ativação. C:\Program Files (x86)\Unitronics\Unitronics VisiLogic_C\Main\Tools\Registration\VisiLogic Offline Activator Quote Link to comment Share on other sites More sharing options...
Mbalust Posted October 6, 2023 Report Share Posted October 6, 2023 The same trouble registering VisiLogic; I keep getting an error about proxy settings. After the updated version, everything is running ok. Quote Link to comment Share on other sites More sharing options...
