MVP 2023 Flex727 Posted August 31, 2023 MVP 2023 Report Share Posted August 31, 2023 Perhaps not strictly a Unitronics thing, and likely there's something I don't understand about the PING function, but often when I try to Ping a Unitronics PLC (connected directly to it from my laptop) I'll get this strange response (see screen cap). Notice the laptop IP address is 192.168.62.251 and the PLC IP address is 192.168.62.208. However it tries to Ping 192.168.50.208. What is it trying to do here? Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted August 31, 2023 MVP 2023 Report Share Posted August 31, 2023 13 minutes ago, Flex727 said: Unitronics PLC Model # ? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted August 31, 2023 MVP 2023 Report Share Posted August 31, 2023 That's your computer identifying itself with it's own IP telling you that the PING did not get a response. It confused me the first time I saw it. Joe T. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted September 1, 2023 Author MVP 2023 Report Share Posted September 1, 2023 23 hours ago, kratmel said: Model # ? It's a V700. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted September 1, 2023 Author MVP 2023 Report Share Posted September 1, 2023 19 hours ago, Joe Tauser said: That's your computer identifying itself with it's own IP telling you that the PING did not get a response. I get that, but what's with the 192.168.50.208? There's no .50 subnet in this network. Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted September 1, 2023 Report Share Posted September 1, 2023 maybe subnet used by another NIC Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted September 1, 2023 MVP 2023 Report Share Posted September 1, 2023 As far as I understand, the result of this test can be reproduced many times. My thoughts: 1) perform this test without connecting the PLC; 2) dial 192.168.62.208 instead of 192.168.062.208; 3) repeat the test by switching the PLC to STOP mode; 4) test another PLC (not V700) with the same settings. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted September 1, 2023 Author MVP 2023 Report Share Posted September 1, 2023 1 hour ago, kratmel said: As far as I understand, the result of this test can be reproduced many times. Yes it can. 1 hour ago, kratmel said: My thoughts: 1) perform this test without connecting the PLC; 2) dial 192.168.62.208 instead of 192.168.062.208; 3) repeat the test by switching the PLC to STOP mode; 4) test another PLC (not V700) with the same settings. Will do. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted September 2, 2023 MVP 2023 Report Share Posted September 2, 2023 I've seen my A/V play funny buggers with addresses at times, with the virtual adapters it uses. Try with it fully disabled, just to check that isn't the cause. And you haven't forgotten any leftover static specs in the adapter settings that might be upsetting things? Quote Link to comment Share on other sites More sharing options...
AlexUT Posted September 4, 2023 Report Share Posted September 4, 2023 Do you have any VPN installed? If yes-temporary disableit, or uninstall, than test again. *I found that installed at my company's Laptop VPN created virtual network switches, allowed only company defined connections. You may have similar problem. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted September 4, 2023 Author MVP 2023 Report Share Posted September 4, 2023 8 hours ago, AlexUT said: Do you have any VPN installed? No. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted September 4, 2023 Author MVP 2023 Report Share Posted September 4, 2023 On 9/1/2023 at 10:10 PM, Ausman said: And you haven't forgotten any leftover static specs in the adapter settings that might be upsetting things? No, I have to use static specs for this job as the customer has assigned .062 subnet to our systems. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted September 4, 2023 Report Share Posted September 4, 2023 192.168. 192.168.50.208 may be a default gateway. 1. Run from DOS prompt "ipconfig /all" and look in list for 192.168.50.208. 2. It may be a Proxy Server, set by company's configuration. Enter "Proxy" in search box and press ENTER. Check if any Proxy settings are enabled. Probably you may see 192.168.50.208 as a Proxy. Disable Proxy and check ping again. 3. In DOS prompt enter "tracert 192.168.50.208 and press ENTER. *It works slow. 4. You can ping 192.168.50.208 if you are at company network. It may answer you if exists and if ping reply enabled for this IP by IT. Summary (not full list): Proxy, Firewall, VPNs, AntiVirus/AntiSpam and other security applications, running by IT. . Sometime helps if you reboot your computer. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted September 4, 2023 Author MVP 2023 Report Share Posted September 4, 2023 1. Done that - nothing found. 2. This is a personal laptop, no proxy servers. 3. I was connected directly to the PLC via crossover cable. No network, no wireless connection. 4. I should have tried to ping that address. Rats. 5. It's a laptop. It gets rebooted every time I use it. Quote Link to comment Share on other sites More sharing options...
