AgustinG Posted April 2 Report Share Posted April 2 Greetings, Last step I took was to update the HMI IP address to IP: 10.10.1.30 255.255.255.0 10.10.1.1 after the next power up, it is stuck in the "Initialization..." screen, does not move forward even after ~20mins. Model is Unitronics USL-070-B05. I've read thru the manual, but there's nothing there about Resetting or Restoring to manufacturer's defaults. I cannot access it via Unistream software either. some background: all of this because I'm trying to get the HMI to display to connect to the PLC via VNC, but no luck yet on this. Any help would be greatly appreciated! Regards, Agustin Quote Link to comment Share on other sites More sharing options...
sgull Posted April 2 Report Share Posted April 2 Hi Agustin If you have the PLC program you could try removing the SD card and CPU from the panel. The battery backup is in the CPU. Leave power off for 15mins and try to start again. you might need to download the program again and enter non retained settings. Sorry, ignore this, I misread the PLC type. Best bet is to contact unitronics support support@unitronics.com Quote Link to comment Share on other sites More sharing options...
MVP 2022 kratmel Posted April 2 MVP 2022 Report Share Posted April 2 Maybe this help topic is useful https://support.unitronics.com/index.php?/selfhelp/view-article/how-to-connect-usl-to-usc-via-vnc If your panel do not start - please send message to support@unitronics.com Support remote connection help to solve your issue. Quote Link to comment Share on other sites More sharing options...
AgustinG Posted April 5 Author Report Share Posted April 5 Thank you both for your replies. I've tried emailing and calling Unitronics support, but have not received responses yet. I'll wait until Friday, if no resolutions, I'll probably move onto another PLC-HMI solution. Regards, Agustin Quote Link to comment Share on other sites More sharing options...
Liquidcaviar Posted November 14 Report Share Posted November 14 Hello, I'm not sure if this topic is still actual, But I have just experienced same problem. in my case it was USP-104-x10, modular HMI+PLC. Customer Reported unresponsive Touch screen behavior, they tried to restart, after which the screen was stuck on initialization. and in the end, it turned out to be just faulty SD card. 1 Quote Link to comment Share on other sites More sharing options...
MVP 2022 Joe Tauser Posted November 16 MVP 2022 Report Share Posted November 16 That is very good information. Joe T. Quote Link to comment Share on other sites More sharing options...
